Pull Latch .. NO BEEP!
kate616
Post by kate616 »
Hi All
Having problems getting roof down. When I pull latches no beep sound ... Any ideas??
Dan
Post by Dan »
just double checking but have you turned the key and pulled the screen across in the boot?
kate616
Post by kate616 »
Yeah doin same things as last summer when it worked (pull screen across, engine on, pull latch..) but no beep noise. The windows go up and down no problem.
marcelnl
Post by marcelnl »
Hi All
one of the many microswitches perhaps, I'd start at the one in the boot checking the cover is closed...
black 206 CC 2.0 (2001)
407 SX 2.0HDIf (2004)
kate616
Post by kate616 »
Ive looked at switch in boot and it appears to be working ok. I was wondering if it could be a fuse? Do we know if the roof has a designated fuse as it doesnt say so in the owners manual
tomasz-206
Post by tomasz-206 »
When I pull latches no beep sound Please help me i have the same problem i can't open the roof. I can't go to servise because I'm from Poland. There's no good workshop in my town and nobody knows what's wrong with my pug. PLEASE HELP
Lyndon
Site Admin
Post by Lyndon »
have you made sure the roller blind cover in the boot is pulled towards the rear of the car ???
tomasz-206
YES :( please help
tomasz-206
Please HELP
lastvts
Post by lastvts »
If my memory serves me correctly there are micro switches in the handles. One of these may have become disconnected or damaged. The micro switch is possibly just stuck closed. Mark the location of the handles with tipex should you have to remove them. The micro switches are pretty inexpensive, but it will probably just be a case of bending them back in to position.
