BAD NEWS
Farouk
Actually, i washed mine on sunday.. .and it leaked.. :sad: I took it to peugeot on wednesday.. and they adjusted the roof and the doors.. they say its a common problem and its just a few adjustments...
Now i drive.. and it goes as silent as ever.. no creaks at all... .and no leaks at all.. the car seems much much stiller...
mmmm
Ask your technical advisor about adjusting the doors.. wen I asked how it solved the problem.. well he just sed... the doors press harder against the seals and rubber.. and prevent the squeks and leaks...
makes sense.
mmmm
makes sense.
Farouk.
rob
col
Lisa B
I'm currently having the same problems with my car after picking it up 2 weeks ago.
Peugeot have ordered new roof seals from France which is gonna take weeks, so they are giving me a courtesy car tomorrow.
I will certainly mention the adjusting of the roof and doors especially if it means I get my car back sooner!!
Thanks Farouk!!!
Thanks Farouk!!!
rob
Tried that Farouk. Just got a duff car :sad:
Ive had a few soft tops in the past, both new and classics so I have tried all sorts of tricks I have picked up over the years. Same story, mine is just a duff one.
But thanks for the thought any way.
Rob
Derek
I got my car washed today and a little water came in around the window seals. Wasn't too bad as they were use a high pressure hose and were obviously not trying to avoid the seals or anything.
I will keep an eye on it, if it is bad enough I will take it back to the dealer.
Derek
Derek
Derek
Lisa B
Hi Col,
Water is getting in through the gaps around by the front roof clips on both sides as well as the back join where the roof folds into the boot.
peugeot have currently got my car in the workshop to replace the seals, but the seals appear to be on back order so not sure when I will get my car back.
I have asked them to look at adjusting the roof & doors as the gap on the passenger side is wider than the drivers side
I will keep you posted
Rachel.
Mine's been leaking ever since I had it in September. Its gone back to the dealership for the third time today. Its already had the seals replaced and the roof realigned to press firmly on the seals. Not sure what they'll come up with this time :sad:
I'll keep the group posted, surely if its obvious there's a major problem with this they can't continue to deny it.
rob
Lisa, I trust that you have been given a loan car whilst you wait for new seals.
It might be of interest but when my car was at its worst in June I 'persuaded'
Peugeot to hire me a 206CC. Well I had paid for a 206CC and through no fault of my own I wasnt going to drive anything less.
If you want to try this then by all means quote me as an example. They are always most helpful with me now.
Rob
