Top engine mount
Fihen
Top engine mount
Post by Fihen »
Hi all, just finished fitting timing belt and water pump and found the top engine mounting where it bolts to the body has come apart. Closer inspection appears that there is no access to retaining bolt/s.
Would it be safe to assume the part ( marked AL4) just sits in a rubber socket???
Any help greatly appreciated
Fihen
Re: Top engine mount
Post by Fihen »
Update: should have mentioned vehicle is 1.6 with tu5jp4 engine
Got any pictures?
I've never done this, but the Service Box drawings may help.
It does seem that the right side mount just sits in a cup. The left side is secured vertically by spindle and capscrew
Fihen
Post by Fihen »
Thank you IanL and gazza82 for your prompt reply. The part broken is displayed as no7 in the service box drawings. The rubber has separated into two parts however, like you say it does appear to sit in a cup. I will take pics of the offending part.
Fihen
Post by Fihen »
Oops, having trouble uploading pics. Google app not letting me copy and paste.
I use imgur to host.
Fihen
Post by Fihen »
Thanks IanL, I have put the engine mounting back leaving it sitting in the cup and will see what happens. Thanks also for the top will get the app.
