Cam belt question
Nickyandalan206cc
Cam belt question
Post by Nickyandalan206cc »
Why can we find out what engine number we have? We have a 1.6 allure. And there's two different cam belts kits on Euro with different engine numbers and different amount of tooths.
Also do you need to lock the crank shaft or lock from the cams?
206cc wife's car
Renault Megane RS hubbys car
Re: Cam belt question
You can find out all the details of your car from the last eight characters of the VIN in Peugeot Service Box. If you don't have access to it, post them and i'll look it up. You can also get the correct part number for the belt from it.
Having said that, the engine number is on the V5 ("logbook").
The answer about pegging is both. See http://www.peugeot206cc.co.uk/repair-206/ mechanical/engine/timing.
Nickyandalan206cc
Thanks, haven't got the log book as we only just bought the car a few days ago.
206cc wife's car
Nickyandalan206cc
Last 8 numbers are 44213547.
206cc wife's car
Engine Serial No 10 FX5N 2363516. Engine Type TU5JP4
Cambelt Part No 0816 H6
However, it is highly advisable to replace the tension roller and idler roller at the same time. The Peugeot kit for all 3 is 0831 R9.
Also, because all the work to gain access will have already been done, it would be best to replace the water pump as well - 1201 E5.
Nickyandalan206cc
Ordered correct part and yep we knew to get water pump too.
Hubby will be very busy later!!
206cc wife's car
There is a "how to" guide on here on how to do it
