Thanks for any info, Sue
Multifunction Display Bulbs
susan
Hi, does the display (it shows MPG and what radio station etc) have bulbs and how do I replace them, as it's lit but just in the middle. Its 2004 1600cc 206cc.
Re: Multifunction Display Bulbs
Pull the cover off and you will see 3 or 4 bulb holders.
Small 2W capless bulbs.
There are two different types of bulb. When I renewed a relative's I took out one of the bulbs and took it into the Peugeot main dealer as a sample so that they could identify which one. They are not interchangeable.
susan
Hi and thank you, thank you, for your replies. When you say pull the cover off, is that the plastic hood that the display is set in, does it just unclip somehow? Really appreciate both of your helps.
Thanks, Sue
Thanks, Sue
susan
Hi, no worries, cover removed fairly easily and display now looks much better.
Thanks again, Sue
Thanks again, Sue
Well done Sue.
- tenpole
Did it just unclip off. At some point I need to get a bulb for one side but I was not looking forward to dismantling the dashboard.
206cc 1.6 2002 Silver.
L200 2.4 Forlife (wifes)
Yes it just unclips. I think you just push it forward (towards the windscreen) then pull up. It is easy and takes seconds.
Dal
does anyone have a link to buying these bulbs online please?
thanks
thanks
2.0 Black 206 CC on a 51 Plate
- tenpole
I think the bulbs might be 12v 1.2 watt T5 capless bulbs.
- tenpole
Finally replaced these bulbs. Now the display is clearly lit up. I notice the button on the clock dash acts as a dimmer switch, the buttons either side are used for setting up time but how do you change the display. At the moment it just has the date, time and temperature outside.
That's probably all you will get unless your car is fitted and configured for other functions ... which work off a button on the end of the column stalks .. not all 206s had all the top end features and you can't just swap out the MFD and get them either.tenpole wrote:Finally replaced these bulbs. Now the display is clearly lit up. I notice the button on the clock dash acts as a dimmer switch, the buttons either side are used for setting up time but how do you change the display. At the moment it just has the date, time and temperature outside.
As gazza says toggle through the various display modes by pressing the end of the right hand stalk. All explained in the owners manual page 79.
- tenpole
Prior to pulling the unit out to change the bulbs it did display a variety of information. The stalk did not seem to do anything.
Edit. Yes the stalk works the display. Pity it does not operate the sterio which I guess is non standard.
You probably don't have the MFD or BSI that support any additional features other than clock and temp ..
Radio stalk may be the separate one on the right.
A 2002 original radio doesn't have a separate screen and works through the MFD ... you may have a non-standard headunit .. can't tell without pics!
