pics and diagrams be great.thank you
cylinder Head
pugpeg
cylinder Head
any one got the cylinder Head torque setting (got new head bolts) for my pug? see siggy,
Peugeot 206 LX 03 reg 1.4 cc 83000 miles.
Re: cylinder Head
I assume you have the SOHC engine with an aluminium block.
If so Haynes says,
Lubricate the threads and underside of the heads of the cylinder head bolts lightly with clean engine oil.
Stage 1 20 Nm (15 lbf ft)
Stage 2 Angle tighten a further 240 degrees
Work progressively and (looking from the front of the car as you are working) in sequence starting at the rear centre bolt then front centre bolt, then working outwards front bolt to left of centre, then rear bolt to left of centre, then rear bolt to right of centre, then front bolt to right of centre, then left front bolt, then left rear bolt, then right hand rear bolt and finally right hand front bolt.
Better still invest in Haynes manual no. 4613. Well worth the £15 or so that it will cost you if you buy from the right place.
If so Haynes says,
pugpeg
Re: cylinder Head
thank you for taking the time to post this
as this is my boys car ill get him to buy 1,
Re: cylinder Head
Here is the pic of What Grandadmonkey has posted.
pugpeg
Re: cylinder Head
also while im here.
when i removed the rocker cover theres a plate over the rocker shaft when i removed that there was what looks like a spacer but only found one of them, now does this go on just one side if so what side or is one missing?
pic is just what i need thank you.
Re: cylinder Head
Not sure. Been a while since I touched one of those. Got a pic?
pugpeg
Re: cylinder Head
Capncol wrote:Here is the pic of What Grandadmonkey has posted.
the arrow is that pointing to bulk head? if so photo will be wrong way round, just i so know
Re: cylinder Head
Arrow denotes front of car (ring gear shows on r/h side of engine when viewed from front)
pugpeg
