just few questions (for now)
just brought my son his first car peugeot 206 lx (1.4) and on the way home clouds of white smoke so have had head off found head gasket has blown so cheep repair £10.50 so while im at it new timing belt and water pump,
so is the crank shaft bolt, right hand or left hand thread? and can i shop no 1 piston coming up to crack crank bolt?
also can i use the original head bolts?
thank you in advance mark.
