clutch problem
pugwashed
clutch problem
hi all,for the past few weeks my clutch has felt different,bit rough but changes through gears fine now when i dip clutch there is a whistling,screechy noise but stops when clutch not dipped any advice appreciated
Re: clutch problem
Sounds like the release bearing is starting to fail
- Flower<3
Re: clutch problem
I think I'm having the same problem, I've only just got my pug convertible. There is a whirring/grinding noise when the clutch is engaged. Would I be write in thinking it the release bearing?
Flower<3
Re: clutch problem
Unlikely, if it was the release bearing you would get noise when the clutch is dis-engaged. i.e. when the clutch pedal is pushed down.
If you get noise with the clutch engaged it is more likely to be gearbox bearings.
- Flower<3
Re: clutch problem
thank you! so... new gearbox? :/ or replacing the bearing? (which ill have to get a mechanic to do) Thanks x
Flower<3
Re: clutch problem
Capncol knows all about gearboxes. When he comes on I'll bet he has something constructive to say.
Re: clutch problem
No pressure then Ron?
Just to confirm. Noisy with pedal up, quiet when down? Yes, or the otherway round?
You have a MA5 box which was used in various Citroen and Peugeot cars & vans in various guises:- Berlingo, xsara, C4, Partner, 106, 206, 306, etc: Check the code on the box (see my answers in the post below)
There is a more in-depth explanation here http://www.peugeot206cc.co.uk/viewtopic.php?f=4&t=14944
Re: clutch problem
[quote="Capncol"]No pressure then Ron?
- Flower<3
Re: clutch problem
Hi Ron, yes that write. when clutch is engaged the noise starts, and stops when the clutch is disengaged.
Thank you
Thank you
Flower<3
Re: clutch problem
I had a 205 like that. With the engine running and no-one in the car you could hear a rustle from the gearbox bearings. Dip the clutch and the noise disappeared. I never did anything about it. After many years my daughter had the car off me, ran it for a couple more years then sold it. The last I heard the car was still running ok.
It just depends how noisy it gets...
