My mrs is having an issue with her car whereby the windows are not working, but neither is the roof.
It happened after I disconnected the battery on the weekend to fix an airbag light issue; ever since they have not worked. Unfortunately I am not there at the moment to look into it further, but she has checked the window fuse and its fine.
I assume there must be a relay or microswitch somewhere which may be broken, or is there something else?
Thanks in advance
Stan
PS Im about to search the forum but any help is appreciated.
No windows or roof
Stan 24v
Stan 24v
Re: No windows or roof
This is going to be a BSI issue, isnt it??? Bugger!!
Enright
A BSI reset following the proper procedure might fix it - done properly it certainly shouldn't hurt.
If that doesn't solve it then a diagnostic from someone with Peugeot Planet 2000 may identify the fault.
Which part of the country are you in? It's worth adding your location to your profile - may throw up an enthusiastic tinkerer like myself local to you who can sort it for peanuts.
BCingU,
Neil.
Neil.
Stan 24v
Thanks mate, will have a go at the weekend. I am at RAF Brize Norton, or at home in Swansea - going to update the proflile now.
Im not used to French cars you see, German cars I would have been all over
girl_interrupted
Did you manage to sort this as i am having the same problem?!
Stan hasn't logged in since last Nov, so unlikely to see this.
girl_interrupted
Oh damn
