How to find engine number
c10ttn
Post by c10ttn »
Hi how/where do you locate the engine number, I want to order and change the timing belt on a 1.6 CC but not sure which one to order. Thanks in advance.
yorkielassy
Re: How to find engine number
Post by yorkielassy »
Engine number is noted on V5
Ex 206 CC'er.
c10ttn
Post by c10ttn »
Don't have the v5 yet just bought the car, is there any other way to get it.
yorkielassy
Ta Cap
Ex 206 CC'er.
c10ttn
Post by c10ttn »
Will check when the better half brings it home from work, thanks
Yorkie that is the VIN number. The engine number is stamped into the engine block. c10ttn, you should only need the reg no to get the right belt kit. Your engine (1.6) is a tu5jp4 (NFU)
