roof and windows work but wont stop beeping
carolcar
Post by carolcar »
hi
the roof on the 206 works fully as do the windows. but
there used to be a beep only when the roof was down and driving along
but today the beeping started happeing when the roof was up or down
where is best to look to get this sorted?
so far i checked the 1 catch sensor in the boot and it looks ok where next?
cheers
ben
Green Bubble
Re: roof and windows work but wont stop beeping
Post by Green Bubble »
Hi Ben,
Check whether there is any leak of hydraulic oil in the boot of the car and, if so, get it quickly looked at. My car wouldn't stop beeping when this happened and there was a leak in the pump.
carolcar
Post by carolcar »
i will have a look is there any area in particular to look at?
Regards
Ben
carolcar
Post by carolcar »
Hi no leaks t all.
Where a re the front sensors to check them and also how do you test?
Is it only beeping when you move off or stationary as well?
carolcar
Post by carolcar »
apparently it is intermitant but mostly when driving
carolcar
Post by carolcar »
any one know where all the sensors are and what they look like
also what is the best method of test?
buggy
Post by buggy »
Try this : http://www.peugeot206cc.co.uk/viewtopic ... es#p112325
found it by searching the forum for 'roof switches'
Owner 478
Just make sure the beeping isn't something else like handbrake on warning, or seatbelt. If it is the roof, do you get the confirmation bong at the end of the roof cycle?
carolcar
Post by carolcar »
hi sorry for late reply
yes the roof operates as it should and bongs from what i can gather from my mum
fabianpwi
Post by fabianpwi »
1. I am having a similar problem.
2. Occasionally, during my drive (especially after I go over a bump), the beeping will start. It will only cease when I do the following:
a. Stop the car.
b. Unhook the roof latches.
c. Push the roof switch (to simulate closing of the roof). Some hydraulic sounds could be heard. Thereafter, a 'bong' will sound off (similar to the one that indicates the complete closure or opening of the roof).
3. It use to happen once a few days until recently, the problem occurs once every 2-5km.
4. Would appreciate some leads/ advice to solve this issue. Thanks.
Sounds like the roof corner latches and/or microswitches need adjustment
