won't start when hot
RACHEL ASH
Hi there, I am new to this site. I am having probs with my 206 yr 2004 miles47000. My car starts fine first thing, but if I was to nip anywhere then get back in it. It wont start, just has a clicking noise-all the lights/radio still comes on. It is getting worse, as it will only allow me to do one journey, then I have to leave it, 2 hours later it will start again. please help.
- Thar
Re: won't start when hot
Welcome Rachel
Is it a 206 hatchback you have? This forum is dedicated to the 206 cabriolet but the cars are very similar. Sounds like a start motor problem to me but I'll let those who know their stuff advise.
Yep. Sounds starter related. Check connections to starter are tight and free of corrosion. A good auto electrician can test your starter for you, and probably repair it too.
If it is not still on the original battery I'd say definitely starter motor.
My wife's uncle has a 2004 206 1.6 SE hatchback. It had the same symptoms. Started fine from cold, but was a problem when hot. A new starter motor cured it.
A couple of years after that it started playing up again but it was losing its radio memory and clock time as well. That time it needed a new battery.
See also:
http://www.peugeot206cc.co.uk/viewtopic ... or#p109973
http://www.peugeot206cc.co.uk/viewtopic ... rter+motor
Let us know the outcome in your case please.
See also:
RACHEL ASH
hi there thanks guys, yes it is a concertable. I am thinking more of a problem in the ignitition?? what do u think.
Why do you think it's ignition? Is the clicking coming from the starter (engine area) or somewhere else?
RACHEL ASH
hi there, the clicking noise comes from under the bonnett. But sometimes if you turn the key really slowly it does sometimes start, but it dosn't always work.
thanks
thanks
OK. I still call starter.
Starter motor Rachel.
- Thar
The clicking is a classic sign Rachel.
RACHEL ASH
thanks guys, i will keep you updated.
RACHEL ASH
hi guys had new starter motor put in yesterdeay. £135 in total, so fingers crossed.
Price doesn't sound too bad. Keep us posted.
rachgreen
Hi can you tell me the outcome of replacing the stater motor?
I have exactly the same problem with my car and beginning to pull my hair out as no mechanic has been able to fix the car!
Thank you
Thank you
It will have fixed it rachgreen. RACHEL ASH will only have come on here to enable her to sort out her problem. Having sorted it she didn't bother to let us know the outcome.
What are the precise symptoms on yours, and what model do you have? Also provide details of age, mileage and service history - we'll try to help you. Welcome to the forum.
