Help!!! Car juddering in 1st & reverse gears?
tonyphil007
Post by tonyphil007 »
Hi there, Im wondering if anyone can help me? ive recently had a new clutch and slave cylinder fitted to my 2001 206cc 2.0l, the only problem is the car now judders whenever i try to pull away in 1st gear or reverse. The car drives lovely and goes into every other gear just fine. Ive also found that if i go into higher revs in 1st gear the juddering eases but as you can imagine this can be very embarressing when at a junction and having to go over 2000 revs to stop the car from juddering. Can anyone help me please?!! :?
Re: Help!!! Car juddering in 1st & reverse gears?
Welcome to the forum.
Sounds like clutch judder.
Who put the clutch in? Can you take it back under warranty?
Causes could be-
Broken/ loose engine mount or bolts.
Warped clutch plate or cover.
Oil contamination of clutch.
"Hard" spots on flywheel due to overheating.
or simply just cheap clutch fitted.
tonyphil007
thanks, i cant take it back under warrenty but i am taking it back to the garage that fitted the clutch for me i will get them to have a look at the engine mounts/bolts dont know if its that though as the car doesnt seem to have the right amount of power either but i will get them to check all of your suggestions thank you
I read your original post as if the problem has only been present since clutch replacement. I would expect at least a 12month warranty on a new clutch.
You now say you are down on power so it could be a missfire. Possibly faulty coil pack
shadow
Post by shadow »
i have a spare coil pack from a 2004 2.0lt if you want it (valeo) i only changed it as i didn't know the history on how long it had been on, was working fine when it came off.
