Recently purchased a 206CC and the heater blower only works at the fastest speed.
Is the problem likely to be the switch or the motor please?
Heater blower only works on fastest speed
Re: Heater blower only works on fastest speed
Resistor block module to heater fan. Sounds as if you need a new resistor block.
Gemma43
Thanks for your prompt response.
Where is this located and do you have any idea as to the approximate cost?
Many thanks
Many thanks
Set the air recirculation flap lever to the recirculation position. Access to the resistor can then be gained via recirculation intake aperture on the underside of the heating/ventilation housing duct.
Rotate the resitor to free it from the duct and pull it into the duct.Disconnect the wiring connector and remove the resistor from the housing. (If access proves difficult, remove the blower motor and remove the resistor through the blower motor aperture).
Manoeuvre the new resistor into position and securely connect it to the wiring connector. Once the connector is securely fitted, locate the resistor in the duct and clip it into position.
Also see the following which you may find helpful:
http://www.howtomendit.com/answers.php?id=239933
Cost of resistor will be around £20 I guess.
Good luck.
Good luck.
Gemma43
Many thanks again, a nice little job for Dad !!
