elecric windows
lisaoley
elecric windows
Post by lisaoley »
My drivers window will go down but it wont stop and then the back window goes down too .... now neither windows will go back up , please help
aaronwillis
Re: elecric windows
Post by aaronwillis »
So you mean they are down fully and now won't go up
Can you hear anything trying to go up
Have u checked the other side ??? And fuses
lisaoley
Re: elecric windows
Post by lisaoley »
aaronwillis wrote:So you mean they are down fully and now won't go up
Hello the windowa went back up after a few minutes, then tried again and they just go straight down all the way without stopping ( you cant stop the windows going down) then same again they wont go back up, cant hear the motor trying,,,,, waited couple of minutes then they went back up :( other side is normal .
aaronwillis
Re: elecric windows
I'm sure you must be pushing it down fully
It has 2 settings if u push it lightly it will go up and down
If u push it harder till u feel a kind of click on the switch they go fully down
lisaoley
Re: elecric windows
Post by lisaoley »
aaronwillis wrote:I'm sure you must be pushing it down fully
Hello again
I know the windows do that but mine are not doing that ,if i put them down they wont go straight back up i have to keep trying then eventually they go up, i read somewhere that there is a sensor where the closes back up after u have had it down but i dont know :(
Ollie
Re: elecric windows
Post by Ollie »
I had this problem recently, they started to go down and even if i pulled the switch to go up they continued to go down. My switch worked on the 2 setting so back didn’t go down as well if I didn’t press the switch all the way. BUT, with the driver’s window down, I would pull switch up and it would send the back one down. Then both wouldn’t come up, took few minutes, I could hear something from the back (like a motor/clicking) when I pulled the switch they came up after 5 mins (no exaggeration) or switching the engine off and on they came up.
Tested with the roof going down and the windows behaved as normal.
NOW - it seems to of rectified itself and its working as normal :? :scratch: :? :roll:
I hardly use my window, I don’t smoke but it was annoying when going to drive-thru's or collecting tickets on entry at NCP's or Dartford toll bridge lol
