Hi everyone,
Newbie here, great site by the way! Gotta prob with my roof at the moment, tried to open it one day and was greeted by a constant beep and no roof movement. This beeping is now becoming very annoying and sounds everytime the car is NOT stationery. Ther is also no bleep to confirm roof catches are unclipped. I need help urgent as i cant stand the bleeping anymore,
BROKEN ROOF!! HELP PLEASE
Hi Willow, and welcome to the forum,
Sounds like a sensor.
swinter & simes produced a useful thread which may be of use to you. They had similar symptoms to you which they managed to sort out.
See
viewtopic.php?id=10625
Regards,
See
Regards,
Flecky
Hi Willow,
I've had some recent troubles with my roof and finally tracked it down to a loose plug/socket connection in the wiring of one of the microswtiches. I figured out the control logic of the roof opening & closing sequence (see my recent posting).
If the roof failed to start opening and you got a warning sound, perhaps the controller thought that the curtain was not drawn across in the boot (check microswitch). It might be due to a faulty microswitch at the manual clamps, making the controller think that it was unsafe to open. However, I've just tried operating the roof with the manual clamps shut, and there was no warning alarm. It just prevented the windows from openign automatically.
If you're getting the alarm above 5 mph, then the controller thinks the roof is not fully clamped which could be for a number of reasons:
1. Manual clamps do not appear to be shut properly (faulty microswitches there perhaps, but these are very difficult to get at)
2. Boot lid does not appear to be shut properly (faulty microswitches at boot locks, or faulty connection in wiring to these switches)
3. The controller thinks it is in the middle of the opening sequence (due to previous attempt to open)
It might be worth 'resetting' everything by disconnecting the battery and letting the brains do a reboot (you've got your radio security code, right?). Before trying to open the roof, does it still beep above 5mph? If so, then check the boot lid lock switches and wiring. If not, then have a go at opening the roof and see what happens.
BTW, I donb't think there ia any 'beep' when the roof catches are unclipped. You only get a beep at the end of the opening or closing sequence.
Good luck!
Good luck!
nicjayne15
sarahwest
hi there i have had my 206cc for years now no problems but the other day i put my roof down and put it back up again and the boot lid wouldnt close! so i pushed it down manually and it wouldnt shut properly hich caused a bleeping noise so i took it to the peugeot garage who repaired the broken hook on thr hinges off the lid but my vehicle still keeps bleeping but im scared to put the roof down incase the lid breaks again im such a worrier and this beeping is driving me crazy also what are the two cans and allen key for in the back off my boot i have no idea im so worried my boot lid is going to fly pff and im going to have a car that keeps breaking help please please
