There isn't a automatic way to restore the avatar's, it needs to be done manually
I've copied across all the avatar's that were stored on the old forum, to access them go to -
profile > Personality > tick the use avatar box > then click change avatar > select default gallery for the avatars that were uploaded.
if your avatar doesn't appear in the gallery it must be on a external link, which at present I'm not sure if that's possible, if not you can upload your avatar, just click on the upload avatar link.
cheers
Lyndon
