My mums 206cc is playing up. Sometimes the blower works, sometimes it doesnt.
I took the blower out and connected it up inside the garage and it worked
I replaced it and it still didnt work. I was playing around and it started working but then stopped.
My mum has also said that sometimes it works, sometimes it doesnt.
Anybody had a similiar error? Any ideas?
I've tried to search on here but couldnt find any answers.
Intermitted Blower fault
- Lyndon
- Site Admin
reap
sounds like a duff resistor pack. pull motor out again.then shove your arm up the tube the motor came from. you will feel the pack on the top of the tube about halway down.
turn 90 deg and pull out.unclip wiring .replace with new.
make sure new clicks back in to tube.refit motor,all will be well.
asuming you dont have electronic climate??
and tis vey tricky to do.
hope this helps alittle
