Miss has jus got a 206cc and wanting to know wheres the best place to buy the silver ones from
I have checked ebay but u get some selling around £50 then some more
cheers
206CC ROLL OVER BARS QUESTION
neildavies
- Lyndon
- Site Admin
have you done a forum search ?
been covered a few times
if not try this (if i remember right)
put the roof down, then gentley but firmly grip the back part of the rear seat, pull up to unhook the back once done you should see 2 nuts undo both nuts then wiggle the factory fit hoop out, fit the new hoops which need a bit of force to get them in, re-tighten the nuts and push the seat back onto the hooks, repeat for the other hoop
make sure the hoops are fastened down enough or when you put the roof back up they might hit the rear window
i measured the height of the factory fit ones first and made sure the new ones were about the same as there's not much clearence
