Hi, i wonder if any one has had the same problem as i have at the moment,
My wife was in our 206 1.4i, T'99 LX, when it just cut out and wouldn't start again, AA didn't have a clue what it was after making a few basic checks, towed it home and began to investigate myself,
No fuel pump prime on ignition,(i have put power to pump terminals and pump is working)
Changed fuel pump relay under E.C.U., No different
Crank sensor checks out ok
Discovered whatever the problem is, it's flattening the battery overnight,
Checked all fuses and connectors e.t.c. all seems fine
Changed ignition block wires for another 1, just to see if it was that-- No different
Noticed heated rear window not working, and im pretty sure it worked before the failure, also Hazzard warning lights now not working but did before,
Got mobile mechanic out, when he plugged his box of tricks into it, it wouldn't let him into the diagnostics, it was saying "access denied" or something like that :rolleyes:
Any help would be greatly appreciated, as i am completley stuck,
Phil
Major elctrical failure
frickley4x4
Thanks for posting the outcome. Bit hard on the wallet I guess. Hope you're back on the road again now, enjoying the sunshine. Best Wishes, Ron
quoman
dont buy a new ecu yet!!! check out my website 1st www.ecuclinic.com its a new site constantly being updated but you can e mail or call me alan
ecuclinic.com for repairs and decodes to most pugs
frickley4x4
