Can anyone help or is it off to the garage I go
Fuse box layout different to the manual
tigertina
Help, My husband fitted a reversing kit to my 4 year old 206CC. Shortly afterwards the drivers side headlight blew (new bulb) then the radio permanent feed disappeared so the radio no longer remembers the code or station settings and now the drivers side sidelights have stopped working.
All the fuses are Ok but the owners manual shows a different layout to the car. Removing the reversing kit did not fix it. Cannot buy a Haynes manual and nobody on the web seems to have the wiring diagrams or the fuse box layout.
tigertina
It's the interior fuse box. My Mum's standard 206 manual shows the correct under bonnet fuse box layout but is wrong for the underdash fuse box. Don't know what bm34/bh28 means, how do I tell?
The roof works fine, leaks like a sieve at the joints
but this weekend is a silicon grease and silicon sealant play time
as per documents found on this site. I will report on the success.
Many thanks
Tina
Many thanks
Tina
tigertina
