Problem 1
I have a 2001 2.0 206cc which I bought but the buttons (Off, Auto, Fan +-, etc) around the air con display dont come on with the lights so you cant see them at night.
I have tried to dismantle the dash to get to the back but there are 2 connectors which I cannot remove.
I've checked the fuses and they are all ok, I think its on the same fuse as the ashtray light and that works.
One thing that does work is the backlight on the air con display (same unit) which also dims when you turn on the headlights.
Problem 2
When I pull away in first gear, the car shudders as it pulls off, this is slightly noticable in other gears but mainly in first.
Any ideas anyone?
Thanks in advance !
Richard
Lights on buttons around aircon display not working
reap
RichJ
reap
cant see pics of the fan
but as a guess id say it was the one that flows internal air over the temprature sensor to regulate the climate control.
usally sits behind the passenger air bag.you will see some slits in the dash near the centre of the car on the airbag.it goes behind there.
peugeout fitted clutch(if it is the clutch)costs about £350ish pounds.
hope this is of any use to you??.
RichJ
