Just got myself some Angel Eyes can anyone give me any advice on how to get my headlights off as they are lose but come abit stuck on where there may be some more bolts.
Cheers
Sarah
How to take off headlights!!
ChillWynston
popeye 819
- Dan
Sometimes what doesn't appear to be plug and play actually is on closer inspection.
Check the connections as some of the adaptors can be removed leaving another plug underneath.
If anyone has problems that tutorials cannot solve then take pictures and post them up here for us to see. (Your questions could be answered a whole lot quicker)
Popeye what probs you having?
Red_Devilette
Changing the lights are easy. You need to take off the small plastic covering on each side, and the small panel that covers the front (the one with the peugeot badge), this sits right below the lights. There are only 2 bolts holding the lights on, as you look at the lights, you have one hidden below the indicator, below the light, i'm sure its a 8 mill socket needed, then there is one on corner near the wing if you look at the light u can see the bracket that holds the light on. Then just need to unplug the lights and replace... Hope this helps
