I `m planning on buying a Gmax suspension but i was wondering what is better 35mm or 50mm.
In my country the roads are very bumpy.
Any pictures of lowerred CC`s will be appreciated!!
35mm or 50mm Suspension?
teddy206 GTi
Don't lower it 50mm.
Even at 30mm it will hit the bump stops on the front end on rough country lanes.
Either drop will be fine on smooth roads but if you want to have the choice to drive on bump roads then the lesser drop is the best.
Another reason to not drop it 50mm is the front arms are less likely to sit horizontally - needed for good steering geometry.
Dabz
my 206 dturbo was originally lowered 50mm and it made it very crashy...eventually when I changed to 30mm we found that the bump stops had been shredded and the suspension struts had been chipped in places where the whole lot was regularly bottoming out. both times I used eibach springs...can't fault the -30mm ones for comfort and handling
Dabz
teddy206 GTi
