Tyre Pressure on 15" alloys
Antoni
Post by Antoni »
Our 1.6 has the factory option 15 " alloys - the sticker in the door calls for 2.5 bar, which is 37 psi (nearly).
Is this the same as everbody else ? as it seems high and I remember reading about this sometime ago on the forum but can't find it.
Antoni
Justin
Post by Justin »
Antoni,
Yep, that's the same pressure as is displayed on the door panel on my 1.6 cc, I have the 15" alloys too. It does seem a little on the high side pressure wise, particularly as the ride is quite hard anyway. Rob suggests lowering it to around 32 psi (from memory - I'm sure he'll correct me if I'm wrong) but I've gotten used to the Peugeot recommended settings now.
Some of the back roads around Stratford-Upon-Avon are threatening to shake my fillings out though ;)
Justin.
