What oil do the factory put in?
carl
Post by carl »
Our CC is getting a little low on oil and needs a top up. I'm usually not keen on mixing different oil weights, but more importantly mixing synth/semi-synth/mineral.
Does anyone know whether it comes from the factory with synthetic or semi-synthetic? I have some Redline 5W/30 fully synth -- will that be OK to top up with?
Huu
Post by Huu »
in AU pug advertised as using Mobil 1 (fully synthetic). I stick with that when i need to top up myself.
carl
Post by carl »
Well it's not the quality of the oil that's an issue (actually Redline is better than Mobil because it has polyol ester base stocks :)), more of its compatability with the existing stuff. The only reason I want to use the Redline is that I have a US quart of it which I use for filling up the TVR.
WebCode
Post by WebCode »
Its filled with 10W40 Semi.. as standard
I Use Castrol RS 10W60 now.. Fully synthetic..
clarelee
Post by clarelee »
In Brisbane our dealer supplied it and fills it with Castrol Magnetec when servicing, they even reccomend it an insert in the manual.
carl
Post by carl »
That means I'll have to drain and refill with fully synth -- I can't just add the fully synth. It's a year old now (13k miles) so I reckon that despite what the manual says it's due an oil change.
I used to use Castrol RS 10W60 in the Impreza. Good for turbocharged engines (they knock the stuffing out of oil) but isn't it a bit thick for a normally-aspirated engine?
The other good oils are Motul 300V 15W/50 and any of the Redline or Amsoil ones. TVR dealer told me they fill the car with 5W/30 Shell Racing oil (which I can't get hold of) and Redline was the only one I could find that came in 5W/30. Seems a bit thin to me, but according to the blurb it's high-quality composition offers the same protection as other oils that are thicker :scratch:
Alex LS
Post by Alex LS »
Magnatec's semi-synthetic though, at least in the UK...
