condensation??
clairendec
Post by clairendec »
Hi Ayone having the same problem as me with 'condensation' I need windscreen wipers on the inside as well as the outside! I have tried using the a/c to demist but it's more than just steam its water!!!!
Help! :( It especially seems to be bad now that it's freezing outside!
BAGPUSS
Post by BAGPUSS »
GOT THE SAME PROBLEM.CAR NOT EVEN 10 MONTHS OLD YET.
ROOF LEAKS IN WHENEVER IT RAINS.
DOES YOUR ROOF LEAK???????
clairendec
Hi Bagpuss! My pug has been into the dealer, apparently my aerial was loose and thats how I was getting water inside! My roof seems to be OK though! my car is 9 mths old and it's had 3 oil sensors (When you switch on you should get boxes, I've been getting flashing boxes, flashing lines etc etc- that's the oil sensor gone!) and I had a new reverse light switch as I had no reverse lights! It seems to be OK for now!
I still love it though!! :lol:
Dan
Post by Dan »
I have really bad condensation probs. I can sort out the windscreen and the heated rear, but the side windows are a problem. Especially when looking out of them at junctions :x
Fletch
Post by Fletch »
I have had this problem in my Galaxy and Alfa, if u have the Air con on resurculate for too long then it can build up in the air con system and not evaporate, for best results always have the climate control on and adjust the temp occasionally, also if u have to have resurculate on only do it for a short while.
Other factors of course can be damp or wet carpets, have a feel make sure u dont have a big puddle under there
