Well this one comes from my usual EU sources.
It seems that after lowering, that the CC can have a tendancy to pull to the left or right.
It seems the cure in the Peugeot books (now this aint a joke ) is to loosen the axel, drive round a corner and then tighten it up again.
How bizarre is that.
A quality fix from peugeot though (suppose at least they have a fix for it - it must be their first).
<font size=-1>[ This Message was edited by: rob on 2002-03-19 22:35 ]</font>
PROBLEM AFTER LOWERING
M275
OOOOF ! Sounds rather scarey to me !
Just had mine lowered 40mm and seems fine... Admittedly a bumpier ride (I prefer the term "more responsive" or "livelier") but Im very happy and expect to be through a set of tyres before the summer is upon us... (too much fast cornering)
M
M
http://www.m275.com/car
MMMM Dont you just love it!!!
I LOVE MY CC
rob
check the tyre pressures first.
Most garages dont bother with this even though they tick it on the Pre Delivert Inspection sheet. I have found 32PSi to be about best.
If this fails try driving on a large car park (superarket after closing) to see if its the road surface that causes the problem.
If this fails then back to the dealer for a full wheel alignment and camber check.
<font size=-1>[ This Message was edited by: rob on 2002-03-24 18:54 ]</font>
Rob
