roof joining Trauma
andrew
Post by andrew »
Has anyone else experienced there roof not fitting snuggly enough to the seal to enable the clips to be closed???
I had this today ... tried it a few times but wouldnt have it .... so I drive ome and try again and all is fine, I cannot imagine what the problem is - will take to dealer anyway, but nice to know if anyone else has experienced it and what was done to fix it - if it indeed will occur again, it is quite alarming, what if it rained??? Gulp!
-- Andrew
[url=http://www.peugeot206cc.co.uk/newowners?id=429]Ex-Owner 429, now 307cc180[/url]
Lyndon
Site Admin
Post by Lyndon »
it might be that the rubber seals either side of the REAR window have got caught/dangled up and the ride home jiggled them/it about - this is only a guess.
you can see them when the roof's down i think or with the roof up, open the boot and look into the corners to see if you can see anything.
hope this helps
