My car is hesitating now after 9 months of use... never had this before, it did it couple of times yesterday, now it is fine... any ideas? should i take it to the dealer?
it is a 1.6l, yesterday i took it for a ride on the highway... it seems fine now... may be it needed some speed... but i´ll check it out as you suggested me... thanks a lot m8
My SE has done this on occasion - normally if I knock the air con off it cures the problem, only seems to happen when the car is first started and even then only once in a blue moon.
