Whenever rains, my belt does the well known annoying noise for a few minutes untill the engine worms-up and then stops. Can anyone reccomend a spray lubricant for noisy engine belt? I know that i cannot use a silicon based spray.
same problem here, i use those lub spray but it only temporary solution, squeek again after few days... i brought it back to them... they replace new belt and one of the pulley wheels. so far a week now... no squeek
Same problem and with mine, but as i hear i believe its not the belt but some wheel there. I went to them (it was hot!) ... they said.. its not a problem!!! (Serious persons!) I expect more noise and i'll go to them again. Plus the wheel of the steering pump is a little bit moving!!!.. Stupid car finally!
I found out that the noise does not come from the belt but from the top pulley. I have used a silicon lubricant, it does stop the noise but is a temporary solution.
gsp i have the same problem, whenever i go to the dealer, the engine is worm and they say everything is ok.
