Bass in the back
SilverCCer
Post by SilverCCer »
Ok, ive never done anything with ICE before (except fitting new front and rear speakers to mah 206CC), but if i wanted to add an amp and a sub in the boot, assuming i can build the box and carpet it and stuff (very unlikely -totally inept- ) how would i wire up the sub and amp and stuff. Dont say take it to a pro unless its totally imperitive cos i like doing stuff myself. How much can actually go wrong? Should i not waste my time and just take it to a pro in the first place? Any tutorials on the web which show you how to do it?
Paul
Frosty
Post by Frosty »
What can go wrong? Well if you don't take your power for your amp directly from the battery and fuse it you can set your car on fire. Seriously! I'm no electrician nor am I an audio expert and that's why I left mine to the experts. It's a personal thing, but as much as I like doing things I know my limitations and in reflection I couldn't have done nearly as good a job as the pro's did for me.
Cheers
Frosty
stephen T
Post by stephen T »
its easy. buy ya self an autoleads amp wiring kit from halfords. and give it a shot. the hardest part is running the wires.
