Please could someone help with the rear wheel alignment on the pics.
I've had the wheels tracked but the garage said the rears are toeing out but there's no adjustment they can do, any idea's what might be causing it ?
Rear wheel alignment question - 206cc 2.0
Slinky
Re: Rear wheel alignment question - 206cc 2.0
When our CC showed odd alignment at the rear it meant a new rear axle ... lots of wear ...
Ronnie
You need new bearings in axle or a reconditioned axle. I ordered a reconditioned axle from IL axles. It was from memory £190 plus £30 for the delivery and pick up of old axle after removal from car. First class service. The biggest problem was torque headed bolts that needed to be cut off as they were impossible to remove. Be prepared to need new wheel bearings and perhaps new back plates.
Peugeot 206 cc 2006 1.6 petrol
Vauxhall Corsa 2016 1.4 petrol
Slinky
Ok thanks for the help and replies.....
