The high and low ports on our 206cc's air con are leaking and I've (rather foolishly) disposed of the old cores thinking I could easily get replacement valve cores
However, this is not true - apparently Peugeot never sold valve cores separately, they only sold a new pair of pipes including valves (part number 6460 LG) but they are now NFP.
Kwik-Fit, Autodoc, GSF, Eurocarparts, Peugeot Museum and Mr Auto don't stock them and I’ve called 8 local scrappies to no avail.
Does anyone here have a couple knocking around I could purchase please or perhaps know of a source I am yet to find please???
I believe they are 8mm thread, 21.5mm long.
I did order some generic ones from Ebay last week and although they fitted perfectly the springs were not robust enough and collapsed when I attached the adapter that connects to the vacuum pump. So I spent a couple of hours vacuuming out on Saturday for the atmosphere to rush back in as soon as I removed the adapter
Any help with sourcing a couple of new or second-hand working valve cores would be very much appreciated please.
Thanks again all.
Ian P.
