High beam not working
batso
Post by batso »
As promised in my intro thread, I now start with the questions.
First question.
High beam doesn't seem to work.
Flicking the indicator stalk backwards, the low beam lights stay active, no high beam, no dash icon.
The headlight units themselves look like some projector type, I'm not sure if this is the standard headlight unit?
Re: High beam not working
Doesn't look standard, ours didn't look like that, ours were UK spec though.
I presume that you've checked both bulbs.
batso
Post by batso »
Sorted the issue - pulled the COM2000 thingy apart and had to muck about with the little slidey contact thingies.
Took a few goes, when I got the high beam sorted out, the indicators didn't work. pulled it all apart again and reassembled with a bit more care, all good!!!
Well done.
