After shutting the passenger door about 10 seconds later I hear a thud as if someones thrown something against the side of the door. Any1 else experienced this. I'm starting to wonder if it's the window clicking into place?? Any help any1?? Also my driver window doesn't always line up properly so I have to put it down and back up again. General prob or just a dodgy car for me?????
Cheers
Thud on window!!!!!
Eye See
Jo,
This is a common problem.
You have noticed the glass not lining up. Assuming you are refering to the pillar between the door and rear glasses, the door glass will either be touching the roof seal or overlapping the pillar.
We have experienced this on our car and the CC courtesy car we have at the moment, together with the door never seeming to latch correctly. The thud is caused as the door glass falls in to place as you pull away.
Our local dealer cured this problem by adjusting the door 'as per a Peugeot technical video'. However, it has reoccured on several occassions and we took photos with a dated newspaper as evidence because it never happens when it is at the dealer!
Hope this helps.
Eye See
Hope this helps.
Eye See
Loyal [b][i][u]ex[/b][/i][/u] CC owner!
Julia
I have also had the "thud" noise from the window.
[img]http://www.addis-welt.de/smilie/smilie/simpson/Smilie04sim.gif[/img] [img]http://www.addis-welt.de/smilie/smilie/simpson/Smilie03sim.gif[/img] [img]http://www.addis-welt.de/smilie/smilie/simpson/Smilie06sim.gif[/img] [img]http://www.addis-welt.de/smilie/smilie/simpson/Smilie07sim.gif[/img] [img]http://www.addis-welt.de/smilie/smilie/simpson/177.gif[/img]
