gear stick movement
micky1
gear stick movement
Post by micky1 »
hi guys does all Peugeot 206cc have excess amount of play in between gears and if not what is the best way to fix this will changing the linkages help. thanks. micky1
Re: gear stick movement
Linkages have rubber bushes in them so if they are worn the links will be slack
micky1
Post by micky1 »
hi and thanks gazza82 how many linkages are on them mine is a 2005 2.0L allure and thanks again.
Three from this pic .. (206info.co.uk)
