Anti polution error
steve747
Anti polution error
Post by steve747 »
my 1.6 16v 206cc 2002 seems to hesitate between gears, i do have a error code of P0121 which is the thottle sensor , can antone tell me if the thottle sensor is part of the Thottle body.
Could you tell me if i need to replace the whole thottle body? or there could any other things to check for this fault.
THANKS
Steve :big-grin:
Re: Anti polution error
I think that is the sensor, accelerator pedal - Part no 1920 X1 on my car, but it may be different on yours. Post the last eight digits of your VIN if you want the number for yours. I believe it attaches to the accelerator pedal.
steve747
Post by steve747 »
Thanks for the quick reply, Wear will i find the VIN number?
Thanks :thumbs:
Steve
Mine is stamped into the metal frame of the boot opening. It is also shown on the V5 ("logbook").
steve747
Post by steve747 »
My VIN number is42534014.
is the part im looking for on this link ,could check for me ..
https://www.ebay.co.uk/itm/253230771470 ... Track=true
Steve
Part No 1920 X1 is the correct part for your car. I found one here: https://www.ebay.co.uk/itm/Capteur-posi ... SwpqRaw4Of.
The VDO numbers do agree, so it seems to be the same part.
steve747
Post by steve747 »
HI Ian
Did you experience hesitation through the gears.
How do I remove this sensor.
YOU have been a great help thank
I have not had a problem with mine. I don't say your problem is that sensor, just that the throttle sensor you mentioned probably is the accelerator pedal sensor.
I think you unplug the electrical connector, undo the three bolts and remove the pedal, and then remove the sensor from the pedal.
steve747
Post by steve747 »
Ian thanks for your help i will let you know if that was the problem..
Steve
steve747
Post by steve747 »
Had a good look under where the thottle is and there doesnt seem to be a TPS there..
attach photos..see what you think?
steve :mad:
From the watermark, I assume that is a photo not of your car. It is probably of a early 206 with a cable operated throttle. Yours has an electrically-operated throttle, going by the VIN.
Here is an example: https://www.ebay.co.uk/itm/PEUGEOT-206- ... SwFShauKuf
steve747
Post by steve747 »
The watermark picture is exactly the same as the pedals are on mine..
i will attach my photo
Yours will be cable operated. The sensor is either near the O/S wing or on the bulkhead. Get someone to press throttle and you will see it moving
According to the Service Docs, there is a modification kit to do away with the cable control and fit the electrical pedal. I assumed that had been done. The Docs don't show the position of the sensor.
steve747
Post by steve747 »
Hi Guys
I would like to thank everyone for there help on this matter, i have managed to find the location of the FPS sensor , it is on the n/s beside the brake fluid reservoir.
Im guessing that the bracket i have to undo is under the wheel arch . and the sensor is behind the throttle cable connection ..i have attached photos incase this matter comes up again , bare in mind its on a 1.6 16 valve engine 2002..
Thanks Again
Steve :thumbs:
