A good Day to you all,
My Girlfriend, recently purchased a 2003 206cc, and i have been assigned the duty of fixing up a few minor issues, (so i can earn those all too valuable brownie points).
and one of these issues is the right hand rear window. Car is left hand drive.
the other 3 windows go down without issue, the problematic window doesn't go down at all. however i can hear motor working and what sounds like cables moving around and about. i haven't removed the rear panel as of yet to see it in action. (a job for next weekend a imagine..)
Since the motor seems to be working in the regulator, should i look into one of those regulator repair kits that are available on ebay?
or should i just replace the entire regulator.
Thanks In Advance..
Sid
Rear Quarter window
Re: Rear Quarter window
Not an answer to your question - I would say open it up and take a look first.
The instructions are here.
So would I Ian
Sid
well i opened it up today and had a look, and as suspected the wiring system of the regulator has some broken pieces. I had ordered the rebuild kit and installed it today and tested the functionality. Tomorrow i put i all back together as today i was having great difficulty putting the regulator back into its place.. lets see where tomorrow gets me...
Sid
well finally got the regulator back intonplace and everything is working fine.
i had a heck of a time with putting in the refurb kit. as the previous owner or the garage that did the work for the PO. had greased the entire mechanisme with some sort of spray on grease.. it was everywhere but on the wires. a heck of a mess.. i should have taken pictures but was too busy swearing and scraping my knuckles trying to get the cable in place with all that grease about.
Just in case - where did the repair kit come from? Is it a Peugeot part?
Sid
there are a number of refurb kits on Ebay.
I ordered one from a UK seller
id post a link but i don't have that ability..
a search for "Rear window regulator repair kit Peugeot 206cc" on ebay will bring them up
Many thanks. I think I'll buy one of each - while stocks last
PIMel
Hi Did you get a lacing diagram with your kit I am trying to fit a replacement cable set but there are no instructions! Its like a 3D jigsaw. Or did you find something on youtube to help?Sid wrote:there are a number of refurb kits on Ebay.
mobivet
Mr Sid can you please give me any advice how to tension all the wires? I purchased one of the refurbishing kits but I have great difficulties putting all that together. It's like the wires are too short...Sid wrote:well finally got the regulator back intonplace and everything is working fine.
Agile
I have a similar problem perhaps?
Rear quarter window goes down but not up unless I can pull it up while I activate the switch.
Is this kit likely to solve the problem?
Tony
2002 206cc Petrol
Tony
2002 206cc Petrol
johnbrander
As a quick try, try spraying some silicone down inside (WD 40 might do) and run the window up and down several times - works on mine !
