My Wife has just been brought home by the AA as she couldn't get any gears
There is still pressure on the clutch pedal so i assume its hydraulic. ? so I presume the clutch has gone.
Its a 2006 Diesel and done 120k
The engine was running while the AA man towed her home for the steering and brakes to still work and when she turned it off there was a jangling noise ?
If its the clutch how expensive will it be to fit a new one. ?
Broken Clutch
- petethepond
Broken Clutch
06 plate 1.6 Diesel Allure HDI
Re: Broken Clutch
The thrust bearings are a very weak point on these cars.
Re: Broken Clutch
Jangling noise does not sound like hydraulic issue. Maybe the pressure plate has failed. Assuming it's a straight clutch replacement, the Service Box says 3hr20min - so say £200 plus a clutch kit (between £50 and £150 - say £100), so about £300. If the flywheel has suffered damage, quite a bit more.
- petethepond
Re: Broken Clutch
It was working absolutely fine with no slip or trouble getting gears, then as my wife depressed the clutch she said she herrd a pop and it just stopped working.
I thought it was the clutch cable until the AA man pointed out it was a Hydraulic mechanism.
Re: Broken Clutch
Probably something out of position on the pressure plate baulking the operating lever - could be the clutch release (throwout) bearing, or a spring - it happens.
Re: Broken Clutch
Until the gearbox is off you won't really know, but after 120k I'd assume if it was still on the original it will need a complete replacement (cover plate, driven plate, release bearing and input shaft oil seal).
I hope it isn't a dual-mass flywheel system as they are not cheap
And there is always the possibility the activating arm has worn and failed. Seen that on a car but not a Peugeot, that's not to say that they don't break on Peugeot's though!
Re: Broken Clutch
This is common on cars where people sit at the lights or a junction for extended periods with the clutch pressed down instead of engaging neutral. The release bearing "saws" through the end of the diaphragm fingers.
If you can get it in gear without engine running, this is most likely the case
In addition to the above clutch kit, a new guide sleeve will be required
- petethepond
Re: Broken Clutch
Got the 1st chance to look at the car in day light yesterday !
With the engine running if i depress the clutchand it goes into gear ok
but when i let the clutch out there a slight judder as if its trying to pull forward but it feels like the hand brakes on (when its not) ?
I can also get it into gear With the engine running without using the clutch but nothing happens
And I can also get it into gear Without the engine running.
Re: Broken Clutch
Either the clutch has broken up, or you have a gearbox problem
Re: Broken Clutch
That's normal.petethepond wrote: I can also get it into gear Without the engine running.
That's not ...petethepond wrote: I can also get it into gear With the engine running without using the clutch but nothing happens
Could be clutch is jammed in the disengaged position but that could also be a differential/driveshaft problem or internal gearbox .. either way it's probably got to come out!
Re: Broken Clutch
Don't think there is any "probable" about it.
Definitely got to come out
- petethepond
Re: Broken Clutch
We will get it looked at a will post the finding....
Thanks Everyone
Have a Great Christmas
Thanks Everyone
- petethepond
Re: Broken Clutch
Well folk's I just reread my post and realised how long its been................wow !
Finally (last couple of weeks) Just getting round to trying to sort out the clutch(in fits and starts) and i have removed all of the bolts i thought i needed to, having had to remove far more ancillary parts to get access that the You-Tube Video intimated, but there seems to be one left ?
Its right beside the aluminium heat shield on what i take is the is the catalytic converter and under the oil exchange unit thing that the oil filter housing is mounted, so how on earth do i get at that one.
Managed to get a 13mm open ended spanner on it only to have it break (one of the jaws fell off.
getting to the point of ringing the scrap man to put "ME" out of my misery.
HELP.
HELP.
