electro valve supply relay status fault.....c1380
Can anyone help as can't get through MOT currently.
This started as an ABS Sensor or wiring fault. We have changed the ABS sensor then it came up as a low voltage warning. now it is the above fault any ideas as it cant be put through its MOT. The ABS light and traction control light is coming on. Only after being driven about a mile when braking suggesting an intermittent problem.
the car is a 206 CC 2 ltr on a 2003 car.
haremach
