Hy Guys
I am new at this topic and i am a bit desperate with my 206 cc in regards to MOT. The car fail MOT twice because of high emissions idle/and other. I have change already the complete exhaust with exception of the last pan, the two lambda sensors, and still the car fails the mot; Any suggestions i do really apreciate.
kind regards
Peters
MOT FAILURE HIGH EMISSIONS
Re: MOT FAILURE HIGH EMISSIONS
Which model? 1.6, 1.6 diesel or 2.0?
Have you had any error messages, is engine management light on (has it been?), etc?
Is the rear box OK and have you made sure there are NO leaks in any joints .. even the last one to the back box can cause emissions errors as it affects the lambda results.
thepor
Many thanks
actually i figure could be the rear can as is the one which wasn t been change; anyway i haven t any management light on, so after install the last can i will check everything. there is any other thing could be for example in the injection system or other?
regards
regards
The only way to find out is plugging it into a PSA compatible diagnostic ... PP2000 is the normal one to use as it's Peugeot/Citroens software!
Jut checking: the eml does come on when you turn on the ignition? it should go out when the car starts. If it doesn't come on at all I would suspect foul-play and someone has broken the bulb behind the dash! Possibly to hide the fact there is a problem?
PS You can add your location in your profile via the user control panel .. any little clues help!
thepor
tanks for you reply again. yes the eml lights on with the ignition and lights off after the engine starts. i have diagbox so i am going to try to find any problem although i am not very keen on it as i have use it only once.
If you answer Gazzas first question so we know which engine we can be more specific with our answers
thepor
Do apolize my car is a peugeot 206cc 2.0 2001. I have order the Map sensor to see if things change. As I said the only I didn’t change was the last pan. In the MOT although is explain why the car fails it is not mention the figures which I have ask them to send it today again , by Law they have to supply don't they?
Thanks for any answer as i have to sort this till the end of the month as the car is sorn and I have to take it out where he is.
Regards
Peters
Regards
Peters
The should provide you with the results of the emissions test, mine does, but I don't know if they have to. A good garage would I'm sure ..
Not sure they keep them on record
My garage will give me a copy if it fails emissions ...
thepor
hi guys
many thanks for all your replies. i have make a full test with planet pp2000 and nothing is coming on on emissions, although it shows 2 errors p0551-is power steering sensor and p0485 fan resistor or relais. after i clear all the errors and the car is clean so far. i am lost really because i made a mot trough online service and obviously they want to find errors to eat money. any ideas , mean should i try those last two things which they are the map sensor and the rear pan.. thanks for your help
It's not all about fault codes. Look at live data and check lambdas are switching, fuel trim and IAT readings as they can all give high emissions
thepor
I have change already the two lambda sensors but ad far as concern the other measures you recommend I don't have any instrument to check it, or there is any other action I could take?
Also I have now the rear back pan which I am going to mount next weekend.
Regards
Peters
Regards
Peters
It can all be done on PP2000
thepor
I have made already a full test with PP2000. The faults there are coming from there is a fan problem and also a power steering bad signal. Both were clear and after making a new test nothing is coming up. I have also made a test to some valves by executing them trough the PP2000 program and I heard them working. ..well any other suggestions?
Regards
Peters
Regards
Peters
