How do I remove the crankcase breather pipes?
gpktm
Post by gpktm »
As the title states. I want to remove the crankcase breather pipes but I'm not sure if I just need to pull hard or there is a special way of doing it?
johnbrander
Re: How do I remove the crankcase breather pipes?
Post by johnbrander »
You need to press the yellow bits in then just pull off, its that simple :)
gpktm
Post by gpktm »
johnbrander wrote:You need to press the yellow bits in then just pull off, its that simple :)
Thanks, bud. Sometimes is THAT simple indeed.
They get very brittle over time ... half expect them to come off in two or more pieces!! :facepalm:
