best back box/muffler for the 1.4
royal206
Post by royal206 »
Hey, recently picked up a 2002 206 1.4 petrol. A bit sluggish, but surprisingly zesty for what it is. I did some air intake work, and I plan to add a back box for more flow. I imagine the factory setup is rather restrictive. Any suggestions? Nothing super loud, but sporty would be nice. I have seen the Ulter system on ebay and it seems to be available and affordable. What do most people use? :santa:
Re: best back box/muffler for the 1.4
Our CC doesn't use the 1.4 engine ... try 206info.co.uk
Artermis
Post by Artermis »
As Gazza said....
But in general terms:
I doubt the restriction of the back box is going to be that measurable to be honest. Restriction in the exhaust system tends to be a lot closer to the engine, typically any mani-cats and main cats will be your source of restriction.
Anything else is a compromise because any restriction points after the cat are going to be silencers - take them out and you are going to make more noise, no doubt about it.
You'd probably see best power improvement in equal length manifold and sports cat but on a 1.4 its probably not worth the investment to be frank as they'll be the most expensive parts to source and replace.
Ben. 2006 1.6 HDi Allure
