Oye Mates,
had a question. I needed both myback wheel bearings replaced left and right and found a vendor on the mexican significant of ebay.
He told me i expressely needed left wheel bearings and right wheel bearings because for the peugeot 206cc they would be different sizes the left was different from the right.
This sounded rediculous to me I argued for a bit over the phone saying how could this make any sense like saying the right wheel is a big bigger then the left. But i accepted it and received the two bearings. The car has spent 4 days with the mechanic and he called me and told me their not the same size and he doesent know how to continue.
Are they two different sizes or is the guy that sold them to me a potato?
Left and Right Wheel Bearings Different Sizes?
- tyealia
Peugeot 206cc 2005 (2014 newish motor)
1.6L, 4 cylinder , 50 litre
Re: Left and Right Wheel Bearings Different Sizes?
Inner diameter [mm] = 25
Mounting bores distance [mm] = 42
Outer diameter [mm] = 129
The bearing is integral with the hub and you replace the hub assembly complete.
See:
http://www.micksgarage.com/ProductDetai ... arid=15704
See:
Yes, he is a potato ..tyealia wrote:... or is the guy that sold them to me a potato?
- tyealia
so i have been trying like crazy to find a new 206cc axle repair kit that fits, and i keep seeing this only for rear left hand side stuff, can anyone explain this
