Hi all. New member
Chestrefeldian
Hi all. New member
Post by Chestrefeldian »
Hi all and thank you for the membership.
I have the opportunity of acquiring. 2 litre, all leather trim, slightly worn 206cc.
All round discs, abs etc.
Everything seems to work ok (including hard top mechanism) apart from the fact that it might need a rear axle replacement.
It needs a lot of cleaning up and has a few bodywork dinks.
I'm tempted to have a go at it.
Any comments welcome.
Re: Hi all. New member
Hi and welcome.
Cleaning up & TLC are mainly labour, so a low cost way of getting a 'CC.
Replacement axles aren't expensive and are easy to change. So long as everything else is OK- Go for it.
Don't forget the timing belt, tensioner and followers, and water pump - if they've not been renewed yet.
Welcome to the forum, and say hello to Chesterfield for me - I used to work and live there in the eighties. My youngest was born there.
Changing the rear axle assembly is made so much harder on the CC by the reinforcing bars under the rear end .. those torx/allen screws will be a PITA to shift!
