I have a big problem with my Peugeot 206, I was driving using the Air Con and suddenly stopped.
I thought that was the common fault, the resistor blow, but checking the car I notice that the resistor is fine. Then I suspected from the blower fan, I got one second hand for 20$, installed and the same behavior, I managed to find some people to check the BSI, the final diagnosis is that is not faulty at all. The wiring loom appear to be intact, no wet damage.
Right now I don't know what to do next, I also didn't have the right wiring diagram. I prefer to consult before doing more purchases.
One thing that is funny, If I disconnect the blower, I got some voltage in the air con switch (green light) and I can turn the speed control, if I connect it, if I turn the air con switch it will turn green and then immediately I turn the fan speed the air con switch turns off.
