roof
Re: roof
They seem to have stopped fitting them on the later models. It lifts the parcel shelf ram which is easy to do by hand. Watch the video on manually closing the roof and it shows what the string does and where it's connected
cuska0121
Re: roof
i have managed to close the parcel shelf followed the instructions on how to reset the roof but still no joy the roof works goes back and all that but the windows are not going down have to put them down first then the roof but still got beeping noise is there anouther way to reset the roof doin my head in now
martyrox
Re: roof
I suppose the only remaining option is to go to a Peugeot dealer for diagnostic "Peugeot Planet" which will name all the faults you have with the roof. You can buy all the diagnostic tools on line but personally I'd go to a specialist. Good luck, Martin.
gadgetrescue
Re: roof
hi everybody. new to the site so bear with me if I ask the same question everybody else has.
I recently bought a 2003 206cc for my daughter. when I bought it the guy said the roof wasn't working. checked online and noticed the shelf wasn't pulled back in the boot. pulled it back, roof worked. a couple of days later, opened the roof, fine, but when I went to close it, the windows didn't go all the way it stopped. looked online, common problem. stripped out the rear seats, panels etc, greased the runners, and it all worked. couple of days later, it wouldn't close. looked in the handbook, manual closing, try that. get so far, no cord. somehow, I don't know how, I did something and the parcel shelf went down, and I closed the roof. yesterday, opened the roof, wouldn't close. tried manual closing again, couldn't get the parcel shelf to drop down. after an hour I gave up, and looked on here. this is obviously a common problem with these, because of all the posts, but I saw several people say that you can move the rear parcel shelf manually, and its easy??????????? how.also saw a post from a member saying the same thing, and in his post was highlighted in pink? CLOSE MANUALLY VIDEO, saying it shows how to do it there. I thought the highlighted words were a link, but they're not. I tried to contact the member, but I couldn't. if anybody knows the answer, i'd love to know, please. it is currently sat undercover with the roof still down. the member whose post I quoted is CAPNCOL.
Artermis
Re: roof
Mate - this is the introductions section of the forum. Essentially this thread is posted in an inappropriate place. Not your fault I know but not the best place for you to get the answers you need.
There is a section dedicated to roofing issues - including the thread on manually closing the roof.
check out the roof section:
http://www.peugeot206cc.co.uk/viewforum.php?f=5
Ben. 2006 1.6 HDi Allure
gadgetrescue
Re: roof
hi artermis. now I am confused. what are all the posts before mine. are they all in an inappropriate place as well. after I registered yesterday I read these posts, but nobody says where these videos are. I've looked at the link you left, and the answer isn't there. do you know where it is?
thanks
dave
thanks
dave
Artermis
Re: roof
Yes, this thread isn't in the best place. As I said, I know that's not your doing and I'm not getting at you for it but it's not the best place for you to get the answers you need - I'm trying to direct you to the best place for you to the best answers as quickly as possible.
If you're really stuck you're better making your own post in the problems - roof section if you can't find the answers you need in there already.
The top dozen-ish posts in the roof section have it pretty much all covered though, so you'd do well to have a read through.
The video you're after is right there mate - it's in the post called "how to raise the roof manually/electrically with windows up". Can't really miss it!
Link is here: http://www.peugeot206cc.co.uk/viewtopic.php?f=5&t=12075
gadgetrescue
Re: roof
hi artemis. I appreciate your help, and I will follow your suggestion about posting in the Roof Section, but I watched all the videos on you tube before I registered here, and the problem I still have is how to move the parcel shelf manually, because I don't have the chord. people say its easy, but no one says how, but thanks again, and I will post a Parcel Shelf only post
gadgetrescue
gadgetrescue
