Right hand top engine mount removal
ribs99
Post by ribs99 »
I'm changing the cambelt on my wifes 2005 206CC and as part of the process the engine mount bracket has to be removed. In doing this I have discovered the engine mount has split in two so needs replacing. The problem is I can't seem to find any way to get at the lower bolt holding the mount to the body.
Here is a picture of the engine mount in question: http://www.ebay.co.uk/itm/Engine-Mount- ... Swc1FXYlvn
Any ideas?
206cc Allure 2005 1.6
Re: Right hand top engine mount removal
In the Service Box Documentation there is no indication of a nut (I assume that's what you meant) for the bottom of the mount, so I assume it is captive, in which case you should be able to just unscrew the mount from the body.
ribs99
Post by ribs99 »
Well spotted, thanks IanL it did just twist off with a little bit of brute force.
:thumbs:
steve747
Post by steve747 »
They are very tight i managed to use a filter chain.
put the chain near the bottom of the mountain rubber.
