flood damage
traceyannsummers
flood damage
Post by traceyannsummers »
Hi guys, can anyone help......
I was forced into flood water the other night by a lorry and ended up stranded, car cut out and had to be towed out :( got her home and my partner has started the repair process, new starter motor, new air filter but my baby wont start, can anyone offer advise on how we can dry her out and get her back on the road please
Slo
Re: flood damage
Post by Slo »
Spark plugs out, spin it on the starter to release any potential water in the cylinders, then drain the oil and refill then refit the spark plugs.
If it doesn't start then its probably beyond repair because water, like oil or any other fluid, isnt compressible so if it gets sucked in it usually results in bent conrods as the pistons rise. Take off the sump to check them.
Could also have popped the head gasket, how fast was the car traveling when it went into the water?
